I have a 300 utility with transmission driven pto and no T/A. The clutch has been replaced and adjusted to specs. The pto shaft spins but not to engine rpm. In other words, it does not spin at the 540 rpm at the rated rpm and will not drive my bushog. I have removed the pto shaft from the rear of the tractor, there is no visible damage, broke shaft, sheared teeth. My conclusion now is the transmission.
What in the transmission needs to be replaced. The tractor moves in all forward and reverse gear. No unusual noises.
With the pto engaged, engine off, it can be turned by hand overcoming a slight drag. Feels like a slipping
clutch. Pictures in the manual shows no clutch in the transmission just constant mesh gears.
