Clint Evans
My M starts good and runs smooth for a few minutes then starts to
miss on number 2. Checked compression valves are good. New plug
new plug wire checked points on that cylinder correct. New ignition
coil. No water in oil no oil in water. Put it under load quits missing but
warm and at idle or fast idle will miss intermitantly. Sounds like it is
late firing or maybe exhaust valve is slow about closing?? Any
thoughts
thoughts
