Distributor Part Number
Where is the distributor part number
located at? I have a super C. I want to
switch the points out to electronic
ignition, there are several pertronix
ignitions. Just trying to get the right
one. Thanks
They don't list them by distributor number. They use the housing number in the picture that is used on a bunch of IH tractors. It's up to you to indicate voltage and positive or negative ground wanted if you have that housing or another housing number listed. If you have a IH distributor it should be the number in picture on a SC.
