Hi. I'm trying to repair the fuel primer pump that is attached to the main fuel pump on a IH 3388 tractor. I have unscrewed the body of the primer
pump from the injection pump but need to remove the plunger/cup from the body. Does the handle unscrew - it does have a small hole on one
side of it?
Another issue I have with the tractor is the TA is not working, when you work the handle nothing happens, it doesn't freewheel just stays in low.
It could be adjustment but looking at where it he linkage enters the transmission it looks to be moving to the full extent. Any ideas?
Thanks
Cameron
side of it?
Thanks
Cameron
