Pete in Holland MI
A friend has a 400 with a wide front axle. The axle mounts to a bracket with sticks forward of the tractor, and the tie rod is out in front, like a whimpy bumper (has been bent by several small trees in the woods. Seems like it would put a lot of strain on the tractor to mount it that way.
Most of the other wide front 400's that I've seen has the axle directly under the steering post, with the tie rod behind the axle.
Is this an aftermarket? Put on wrong? Special purpose?
Just curious.........
Thanx !
Pete
Thanx !
Pete
