806 injection pump shaft
oldcatman
New User
Will the injection pump shaft and pump from a 806 converted from rd pump to roosmaster pump work on a tractor that come out with a roosmaster pump? Thanhs
When changing from the RD pump to Stanadyne/Roosa pump you will need all lines and drive adapter, front plate with the spring loaded button, and I used the Roosa filters/lines also, and any other parts to make the change easier. The salvage yard I worked with let me do the removal so I could be sure everything needed was there for the change.
