rosedale123
This is the one that had the miss. Adjusted the timing with a timing light and she ran like a top ; ran great for hours of mowing. But then...... the miss has come back. I will check the timing and check to see if it has moved . If it has moved ( the timing) , does it sound like there is something something worn in the dizzy? I have read about the "bushing" but not sure where that is and how to fix - could that be it? Any and all help is appreciated by my Dad and I. I hope the next time I post I can tell you the "fix".... with your help.
Thank you!
Thank you!
