Is there anything that goes in between the radiator and the front end where the radiator mounts on the bottom? I'm thinking a rubber bushing, washer or something. This is on a Super A.
Yes, a rubber piece that IH called a "pad". The part number is 47240D. I haven't checked, but Steiner's is likely to have a replacement.
Yes, a rubber piece that IH called a "pad". The part number is 47240D. I haven't checked, but St**n*r's is likely to have a replacement.
Maybe it will show in modern view this way.
(quoted from post at 10:45:37 10/07/15) I'm thinking I cut some out of a car tire sidewall for mine. gm
hat should work OK. Pieces could be cut out of some old rubber belting too. It may take 2 thicknesses of belting. With the right thickness, the two ends for the lower hose should be pretty well in line.
I took what was left of the original to a local rubber shop. Dug through their scrap pile tell I found a piece with the proper thickness, and just cut out the pads.
A couple pieces of mud flap rubber. Every so often the mud flaps on the grain truck get a little shorter.
