Over the past year I have been working on "reviving" a 450 lp. It's now running and all back together but need a little help with the pto.
With the lever forward and engine running the pto runs all the time. When I pull the lever back then engine does load up some but the pto never stops spinning.
I assume with the pto lever forward that would be on the "on" position. If that is correct what would need to be adjusted to get it turned off?
It does have the IPTO but it is NOT the 560 style.
