Greetings.
I have a good running H tractor which has developed a problem. I lost all gears except 5th gear. I've been lurking on here and found the thread about a worn shifter base. I removed the pin to look down below the shifter and found the three rails that slide the tractor in and out of gears. Unfortunately, those rails were in their correct positions. I put the shifter back in place and can move the gears in and out of their correct locations but the tractor does not go into gear. Everything 'feels' right when I'm shifting gears.
5th gear works fine and that's what confuses me. I'm stuck. So is my tractor. Anything I can get from you folks would be helpful. I'
m mechanically inclined but probably not enough to go too far into this tractor. Thanks.
Tom
Tom
