Need some guidance on trying to wire a new electronic ignition on a IH 424 gas that currently has a ballast resistor on it. It is a 12V negative ground. On one side of the resistor connected is the electronic fuel pump and the wire to the starter which both connect to the positive side of the coil and the other side has a black wire going to the switch. I assume the red wire from the new electronic ignition and the black switch wire goes to the positive side of the coil and the new black wire goes to the negative side of the coil. What do I do with the electronic fuel pump wire and the starter wire? Would they be hooked together?? Clueless!!
