My 560 has the tel-a-depth system still in place - complete with the trashed gears in the control valve.
After reading around a bit, sounds like I could live just as happily with a "normal" valve in place of the tel-a-depth valve, and not worry about little gears, linkages, and timing, etc.
But what I don't know is - can I still use the steel lines that run back under the seat. These lines mount to the top of the tel-a-depth valve, and I'm unclear on whether or not the bolt/port pattern is the same on all of the valves - or exactly how all that works.
I just can't see in there clearly enough to figure out how the whole assembly goes together.
I would prefer to keep the other two valves open for other purposes - and have this new replacement valve dedicated to the fast hitch, and I'd prefer to do that using the current steel lines to the back of the seat.
Is this a no-brainer, it just fits kinda deal? Or will I need to do some creative plumbing?
