Over on the Ford board I was told you would have an answer for me. I have a Ford 3000 with a Zenith Type 67 carb. It has a fixed main jet (#29) and a plug (#27)
The only adjustable main jet I can find (#27A) is a Zenith 71-28 but it isn't listed for my carb. I really need to adjust the main jet on this carb. Will that adjustable main jet fit my carb? If not what do you suggest?
The problem is that it runs fine at low and mid range. But it is lean at higher RPM's, has no pulling power and pops and sputters. You can see the original thread here:
http://forums.yesterdaystractors.com/viewtopic.php?t=1146042&start=0
Thanks.
Thanks.
