TractorLinks.com
Database Forum Testing Area
Test
James Howell
06-23-2014 17:20:07
Reviewed the INSTRUCTIONS AND PARTS LIST FOR John Deere General Purpose Tractor Model B Dir. No. 190__7-38 page 4.
Starting Engine
1. Close radiator shutter. Set gear shift lever in neutral (Fig. 3) and pull clutch lever back.
2. Advance speed control lever halfway.
3. Drain fuel from carburetor.
4. Turn on gasoline (fuel control handle to mark G.)
5. Turn (clockwise) carburetor load needle and idle needle lightly against seal to close. DO NOT FORCE. Open load needle one turn and idle needle 1-1/4 turns. (Fig. 9.)
6. Open compression relief cocks. Close choke by pushing lever down.
7. Turn top of flywheel forward (counter-clockwise) to start engine.
8. As soon as engine fires, open carburetor choke immediately to prevent flooding.
Using the above steps as the "foundation" to starting the engine on "Uncle Earl", the following steps work best for this tractor.
1. Open the valve on the fuel filter.
2. Open the compression relief cock on the pulley side.
3. Pull the clutch lever back and set the gear shift lever in neutral.
4. Advance speed control lever halfway.
5. Turn on gasoline (fuel control handle to mark F.
6. Open the compression relief cock on the flywheel side.
7. Close choke by pushing lever down.
8. Turn top of flywheel backward (clockwise) to pull fuel mixture into cylinder.
9. Turn top of flywheel forward (counter-clockwise) and stop before magneto fires.
10. Repeat steps 8 and 9 two more times.
11. Turn top of flywheel forward (counter-clockwise) to start engine.
12. As soon as engine fires, open carburetor choke immediately to prevent flooding.
13. Continue to turn top of flywheel forward (counter-clockwise) to start engine.
Hope this helps.
