Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Database Forum Testing Area
Topic: 550 Oliver
[Return to Forum]
poppy
03-16-2013 10:48:10
24.179.83.171
My neighbor has a 550 gas s/n 850519, which seems to make it a 1960. It belonged to his FIL. It has been setting in an open shed for about 10 years. I have told him several times that we should get it into my shop and see if we can get it running. We plan to do just that this weekend (in my shop, not running) . The problem is, This is the only one that I have ever looked at. First thing we need is an operators manual. Where is a good source for a good manual. Several sites on the net have them, but I would like some advice before ordering one.
For what little I can find, it appears to be a 12 volt. At least that is the worn out battery on it now. I have not found an oil pressure gauge yet. I want to prime the oil pump before trying to start it. Don"t know if engine is stuck or not.
Not sure what I have gotten into. Any advice would be appreciated.
[Reply]   [No Email]
El Toro
03-17-2013 03:57:06
108.3.218.181
Re: 550 Oliver in reply to poppy, 03-16-2013 10:48:10
If it's a gas engine pull the sparkplugs and squirt engine oil into all the cylinders. Jack up one of rear tires, put the tranny into the highest gear and rock what wheel to see if the engine is stuck. You can prelube that engine if you have a pressure vessel and can plumb into the oil gallery. If there's no pressure gauge I would install one. If it has points I would rub them with some 320 wet or dry until shiny. Check the engine oil for water or antifreeze. Put in some fresh gas. Install a fully charged battery. Use a volt meter set on dc volts and with the points open and the ignition switch on you should have battery voltage on both small terminals on the coil. Put your request over on the Oliver forum as you will get more help. Hal
  [Reply]  [No Email]
ASDFGHJKL
03-17-2013 19:05:12
76.6.129.140
Re: 550 Oliver in reply to El Toro, 03-17-2013 03:57:06
TEST ONLY - IGNORE
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
