TractorLinks.com
Database Forum Testing Area
Re: starter keep engaged in run position on a stx 38 black
El Toro
12-19-2012 08:45:57
Sounds like your switch keeps sending battery voltage to your starter after the engine starts.
Can you post a picture of the starter switch? Is there a run & start position on the starter switch? Hal
tonymccann
12-19-2012 16:46:49
 Re: starter keep engaged in run position on a stx 38 black in reply to El Toro, 12-19-2012 08:45:57
yes there is off run start position it tries to start in run position i have a new switch has 5 connects on bottom of it. cant be screwed up in the pluging in of it . can something be putting voltage through the switch should it start in run position
El Toro
12-19-2012 18:36:48
 Re: starter keep engaged in run position on a stx 38 black in reply to tonymccann, 12-19-2012 16:46:49
I think the problem is in your switch so when your engine starts and is in the run position there shouldn't be any battery voltage feeding the starter. Hal
