| Database Forum Testing Area |
Topic: starter keep engaged in run position on a stx 38 black
[Return to Forum]
| Author |
[Modern View]
| tonymccann
12-18-2012 13:52:19
24.1.243.219
replaced key ign and silonoid |
| El Toro
12-20-2012 05:46:51
108.3.143.30
Re: starter keep engaged in run position on a stx 38 black in reply to tonymccann, 12-18-2012 13:52:19
| You may be better off to use a toggle switch for the ignition and a starter button for starting the engine. Hal |
| El Toro
12-18-2012 14:14:33
108.3.143.30
| Your starter gear may not be retracting, check it for a broken spring. Hal |
| tonymccann
12-19-2012 02:42:10
24.1.243.219
Re: starter keep engaged in run position on a stx 38 black in reply to El Toro, 12-18-2012 14:14:33
| the spindle will retract its on a cork screw , when i turn it on off position it comes down , when you start it it engages the starter in the run and start position , it should not engage in run position. new silonoid new ign john deere says starters fine was tested . no one has heard of this before . can it be the pto sending juice through something , no clue here thank you for your response |
| El Toro
12-19-2012 08:45:57
108.3.143.30
Re: starter keep engaged in run position on a stx 38 black in reply to tonymccann, 12-19-2012 02:42:10
| Sounds like your switch keeps sending battery voltage to your starter after the engine starts. Can you post a picture of the starter switch? Is there a run & start position on the starter switch? Hal |
| tonymccann
12-19-2012 16:46:49
24.1.243.219
Re: starter keep engaged in run position on a stx 38 black in reply to El Toro, 12-19-2012 08:45:57
| yes there is off run start position it tries to start in run position i have a new switch has 5 connects on bottom of it. cant be screwed up in the pluging in of it . can something be putting voltage through the switch should it start in run position |
| El Toro
12-19-2012 18:36:48
108.3.143.30
Re: starter keep engaged in run position on a stx 38 black in reply to tonymccann, 12-19-2012 16:46:49
| I think the problem is in your switch so when your engine starts and is in the run position there shouldn't be any battery voltage feeding the starter. Hal |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
