TractorLinks.com
Database Forum Testing Area
model M crankshaft pulley
lea barr
11-26-2012 15:47:39
My model M crankshaft pulley is loose, all that holds it on is a pin thru the crank, does anyone have any ideas on that , should I shim the crank or get a new pulley? It doesnt seem like a very good fit, the pulley inside diameter is bigger than the crank dia. (sloppy fit)
El Toro
11-26-2012 18:24:01
 Re: model M crankshaft pulley in reply to lea barr, 11-26-2012 15:47:39
You can probably find a good used pulley. You need to make sure the hub doesn't have a lot of worn grooves from the oil seal. You can use a speedi-sleeve over the hub if it has minor wear grooves. It may a good time to replace that front seal. Hal
