Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Database Forum Testing Area
You were right again HOBO NC
Plane Bart
07-12-2012 17:14:55
Went through the hydraulic system and found two problems the first was obvious I had put the lower section of the linkage to the intake control valve in backwards had it installed backwards on the wrong side of the upper control arm.
The other was the spring that gos to the ram cylinder was connected to the upper control arm instead of in the notch on the lower control arm.
Problem is solved hydraulics work good and strong now.
Thanks HOBO
