T340 International Crawler Engine Swap
Ethan Taylor
New User
What all pieces of International equipment run the gas c-135 engine found in the t-340 Crawlers. Reason I'm asking is i just bought a used engine that was a C-135 and the bell housings was different. Im thinking it may have came off of a older tractor like a lettered series (C OR H) or something. Any info would greatly be appreciated.
There was an earlier post a couple of years ago here on exactly this issue by the guy from Crawler Heaven in NY. YOu might search the archives or contact him.
From what I know, buy the engine out of a crawler, or not at all. Also make sure to buy the same part number block, there are differences.
Lavoy
IH made the C135 for lots of different uses. Most of the internal parts are the same, but several different blocks were used. Do you know the casting number on your block? I'm not sure if any of the ag or industrial applications used the same block as your crawler.
