Its a long time since I've seen an 1150 but seem to remember repairing the brake cylinders,as far as I can recall those cylinders were fairly standard Lockheed parts,7/8" if my memory is correct but I not 100% about the size,its easy to measure them,I used to get a repair kit from an auto parts shop going by the size rather than a part number, with the right size seals and a rub of a honing tool the machine would be back at work pronto,of course if the cylinder bore is too bad that would be no good but if the cylinders are ok they will be as good as new when you put new seals in,see what size you need and ask at your auto shop.
AJ
