Yesterday's Tractor Co.
Shop Now View Cart
Re: Welding vs epoxy on block cracks
09-26-2012 01:52:51
You need a Cat mechanic to look at that block and determine if the liner seats need to be re-cut, its the top of the liner where the gasket sits that seals the compression in,the liner hight is crucial as it determines the pinch on the gasket,he will know if the liner can be reused but that is not common practice as the liner seat can go off square and will not sit even,he also will advise you about the cracks,nose around your Cat dealer and you might find a field service engineer that that will help you out for a six pack or two.
Good luck
