Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: 555a backhoe
[Return to Forum]
kenben
09-25-2012 16:38:21
76.0.164.201
Ford df7114
Backhoe goes in reverse everytime when shifting lever on steering column back.
For it to go in foward the lever has to be shifted foward 2,3,4 times back and foward.
is there an adjustment for this?
Thanks,kb
1950 ford 8n
1985 ford 555a backhoe
[Reply]   [No Email]
Roy Suomi
09-27-2012 18:07:08
76.190.200.252
 Re: 555a backhoe in reply to kenben, 09-25-2012 16:38:21
Under the machine inside the clutch housing , you will find a small steel plate bolted to the bottom.. Take the plate off and you will find a small steel ine with a plug in it.. This is the operating pressure of the directional reverser.. Install a hose and gauge into the line fitting.. This will tell you the transmission pressure .. With stabilizers down so rear wheels are off the ground and backhoe down too,I like to put jack stands under the back of the backhoe just for giggles.... someone can run the reverser while you check pressures.. If forward is much lower than reverse , that indicates a leak in the forward clutch circuit..Disassembly of the machine is needed if forward pressures are too low.... Loader blocked in full raised position , stands under loader front support.. Unbolt engine with axle attached . Be sure to use wedges between the axle and front support so the engine doesn't flip to the side..I use a good floor jack to roll the engine out..Sounds easy , but it's a little more work than what I described..
[Reply]  [No Email]
Roy Suomi
09-25-2012 16:59:57
76.190.200.252
Does the lever go all the way into forward ?? There is a blocker valve on top of the transmission front cover that won't allow a shift if the engine speed is too high..Keeps "reverse to drive slams" to a minimum..If this isn't the case.... The forward clutch sealing rings might be on their way out..
[Reply]  [No Email]
kenben
09-25-2012 17:09:21
76.0.164.201
 Re: 555a backhoe in reply to Roy Suomi, 09-25-2012 16:59:57
How would one check these seals.it seems to need an adjustment.
Thanks
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
