Hello guys. I need some help with my 175b loader. It does not have pushing power. I have to use in low range 1gear. Works good in 1st but I think it could be better.
When put in second gear position which would be 3 rd or 4th high range the drive shaft to transmission stops turning when under very little load. When at idle drive shaft turns. The torque converter preassure reads good on gauge all the time. Any advice would be good.
Same happens when in reverse. Operates in 1gear and any other gear shaft stops turning.
