Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: Cat D5 94J Clutch and brake issues
[Show Entire Topic]  [Return to Forum]
NCWayne
09-17-2012 19:55:11
69.40.232.132
According to RichiWiki the D5 replaced the D6B. Both should have a D333 engine, although it appears one of the 6's built overseas had a D315 instead, and one of the powershift 5's had a D330. Depending on the year model they should all be approximately the same HP ( within about 10 to 15 HP depending on the actual age/serial number).
That said I know many older, direct drive machines had a brake that stops the driveline from spinning when the clutch pedal is depressed and the clutch releases. Wether yours has one or not I can't say for sure as I've only worked on the Power shift eqipped machines in the D5 and 6 series, but it's something you might want to check. On the machines I have worked on that had them, they were usually a royal PITA to get working because between worn lining, and worn linkage holes, they were all a real challange to adjust and make work properly.
As far as the 6 vs the 5, I just built a D333 in an older D6 last year. As far as rebuilding goes, your looking at somewhere around $2500 to $3000, per cylinder, to have one completely rebuilt. This includes labor taking it out and putting it back in, as well as building the engine, machine shop charges, aftermarket CAT parts, and in the case of the one I did, a new head at about $2500.
In other words if the engine on the 5 is freshly rebuilt and the gear grinding problem is something relatively simple to fix like a driveline brake, then I'd say the 5 is the way to go. If, on the other hand, you find something serious with the 5 causing the grinding then your more than likely looking at having the clutch pulled to solve the problem and, unless you do it yourself, your looking to pay the extra $2500, or more. So, one way oyur looking at a possible $2500, and the other a definate, extra $2500. Personally I'd rather pay the extra on getting a a machine with a know, good, rebuilt engine than on one with an totally unknown engine....the rest of the machine (ie the undercarriage, etc) all being equal or nearly so.
Hope this helps. Wayne
[Reply]   [No Email]
Bob/Ont
09-18-2012 08:28:16
70.26.63.56
 Re: Cat D5 94J Clutch and brake issues in reply to NCWayne, 09-17-2012 19:55:11
The master clutch has a brake to stop the drive shaft when shifting gears, not expensive.
As for steering, brake is worn out, drum might be rough and will shorten lining life if not replaced too, medium expense.
Later Bob
[Reply]  [No Email]
NCWayne
09-18-2012 21:32:08
69.40.232.132
 Re: Cat D5 94J Clutch and brake issues in reply to Bob/Ont, 09-18-2012 08:28:16
Thanks for the input on the steering. Somehow I missed that when I read his post last night....Must be getting old....LOL
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
