Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Brake reline question
AJ.
09-12-2012 11:18:16
Pity that after all the work you have done,did you check the bevel gear to pinion backlash,did the ware pattern look OK on both,usually a bad whine in reverse is caused by the backlash been either too tight or too loose,do you know the history of the tractor,sometimes the bevel gear gets changed without the pinion and as they are matched sets no adjustment will rid it of the whine if the gears are not meshing right,the steering clutch issue sounds like the friction material is worn off some of the discs and they are sticking to the driving ones and not letting go till the clutch is fully disengaged,then you can hear them grouch and let go abruptly,hope you can sort it without having to tear it apart again.
Good luck
AJ
