TractorLinks.com
Re: Roosa Master question
george md
09-11-2012 22:24:39
Steve,
Any thing in the ball check has to come from within the pump as there is a very fine mesh screen in the inlet of the pump. The dirt you mention should look like coffee grounds and it is the remains of the governor weight basket drive. When the drive completely disintegrates the 2 pieces of the drive will cut off the rivets and when that happens ,you no longer have a governor and there is no limit to RPM.
Send me an email with a phone # and I'll get you thru the project, I do them regularly and keep most of the parts.
george
gusbratz
09-12-2012 03:00:57
 Re: Roosa Master question in reply to george md, 09-11-2012 22:24:39
on the left you see an original gov. weight basket. there is supposed to be a flexable ring betweeen the rivets, thats what drives it. it disinigrates and dissapears into your return line. see the traces of brown stuff around the rivet heads. on the right is the new upgraded solid one that won't wear out. this is from my case 530 db pump. if i kept running it like this it would wear the rivet heads off because that is all that was driveing the govenor weights. hope that helps.
