TractorLinks.com
Re: Blue devil don't work
Old Magnet
09-09-2012 21:57:15
Did you check liner height when you changed head gasket?
Cat u9 u9
09-11-2012 21:01:32
 Re: Blue devil don't work in reply to Old Magnet, 09-09-2012 21:57:15
Nope it was higher than the block
And it had a carbon ring that I was told not to
Mess with
No ring groove. That I could feel
Bob/Ont
09-12-2012 10:27:15
 Re: Blue devil don't work in reply to Cat u9 u9, 09-11-2012 21:01:32
9U,some things you need to understand, from what I get from your post.
The carbon ring is very good, that is correct.
It means that your rings are not letting any oil past them. Now getting to your major problem the constant blowing gaskets.
Take the old gasket and look where it was blown, you may have more than one spot.
Then look at the liner tops in those areas for any signs of the carbon washed off the liners and pistins.
Then polish the tops of the liners and block clean.
Each liner must be clamped down with an H bar to 60Lb Ft. and the height of it's flange above the block measured with a dial indicator in 4 places around the flange. Projection should be 0.004" to 0.008" with each liner's measurement with in 0.002".
You most likely have a low liner, you can get the piston and rods out the side but if you take the pan off!!! The oil pump and ballancer comes with it!!!! The ballancer weights must be timed upon assembley. ""any piston on TDC and the weights at the bottom.""
Use one of the 1/2" mounting bolts to lock weights untill the gears are engaged, then be sure to take it out.
When you get it apart new liners might not do it, liner seats might need cutting and shimming but will get into that then.
Later Bob
Cat u9 u9
09-13-2012 04:34:37
 Re: Blue devil don't work in reply to Bob/Ont, 09-12-2012 10:27:15
I'm going to check today thanks bob
Old Magnet
09-12-2012 07:30:57
Do you know the correct procedure and specs for checking with the liner clamped down?
Bob/Ont
09-10-2012 15:55:15
Blown head gasket is most likely a low liner.
Big job to fix right but the only way to go.
Later Bob
