TractorLinks.com
Re: D2 Fuel Injector Pumps - Leaking
Old Magnet
09-07-2012 20:02:31
The 2A3307 seal is the correct part number. Did you use Cat parts or aftermarket? Usually don't have a problem with the Cat parts. These are the same seals used on all the early fuel injector pumps.
Nate88
09-08-2012 05:50:45
 Re: D2 Fuel Injector Pumps - Leaking in reply to Old Magnet, 09-07-2012 20:02:31
We used genuine OEM Cat parts. One thing I did notice also when we removed the pumps, there was another smaller profile, larger diameter oring shown in our D2 parts manual. They seal the openings in the main pump housing under each pump, where the plungers pass through to the cam. We installed new ones while we had it apart. Sounds like the 2A3307 oring should work, guess we will have to keep looking for the leak source.
