TractorLinks.com
Re: JD450B engine swap.
walton boy
09-06-2012 19:24:24
Short answer is yes it will fit. May be more work than you want to do. Some things to think about are 239 came in heavy and light blocks. This may not matter in a 450b as the block is likely not stressed. The 239 may be out of a compressor and need the bell housing adapter from from the 219 and depending on the tach drive on the cam may require the cam to be changed.
The injector pump on the 219 likely will not fit the 239 due to different mounts. I recently replace a 276 with a 239. It worked but was way more work han I thought.
