TractorLinks.com
Re: JD 690B-how to check and set relief valves
Roy Suomi
09-02-2012 05:46:16
Sure...You bet it can.. My test will only show the lowest relief valve setting.. There are a gammit of relief valve tests..There are circuit relief valves and main reliefs that need to be set. If you know someone that can read your flow/pressure readings with a flowmeter, that would eliminate a worn pump..Usually relief valves don't change unless a spring looses it's tension. Then even after resetting the relief it can return to a lower setting due to a spring weakening..
