Yesterday's Tractor Co.
Shop Now View Cart
Re: JD 690B-how to check and set relief valves
09-02-2012 04:16:14
Thanks Roy and John. With the boom lift cylinder deadheaded, is it only the relief valve for that circuit that determines the relief pressure? Could any one relief valve that is relieving at too low of a pressure effect all of the circuits?
Roy Suomi
09-02-2012 05:46:16
 Re: JD 690B-how to check and set relief valves in reply to jacks, 09-02-2012 04:16:14
Sure...You bet it can.. My test will only show the lowest relief valve setting.. There are a gammit of relief valve tests..There are circuit relief valves and main reliefs that need to be set. If you know someone that can read your flow/pressure readings with a flowmeter, that would eliminate a worn pump..Usually relief valves don't change unless a spring looses it's tension. Then even after resetting the relief it can return to a lower setting due to a spring weakening..
