| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: 1953 Oliver Cletrac - Fuel Pump
[Return to Forum]
| Author |
[Modern View]
| Dave Goble
08-29-2012 16:48:06
75.101.82.12
I have a 1953 Oliver Cletrac Model DDH with a Hercules Engine that while idling after been in use for some time simply died and would not re-start. I believe that there is an issue with the fuel injection pump based on preliminary evaluation. I need to find a source for both information and parts or replacement if necessary for the pump. |
| DW Goble
09-08-2012 13:22:10
208.106.47.128
Re: 1953 Oliver Cletrac - Fuel Pump in reply to Dave Goble, 08-29-2012 16:48:06
| Fuel pump is Bosch; fuel seems to be making it through filters with no restrictions, no air and no debris. Removed cover plate from fuel injection pump and rotated shaft with no movement within the pump. When coupler is unbolted from the shaft, shaft to pump easily turns with no resistence and no movement within the pump. Any thoughts at this point? Special procedures for removing fuel pump? |
| J. Schwiebert
08-29-2012 19:07:35
209.143.28.10
| I agree with DGH, but some of those later DD crawlers used a Roosa Master injection pump instead of the Bosch. The priming pumps on those had a habit of sucking air. So how about more details, which injection pump you have and if you have fuel flow to the pump, etc. |
| Dave Goble
08-30-2012 08:48:21
75.101.82.12
Re: 1953 Oliver Cletrac - Fuel Pump in reply to J. Schwiebert, 08-29-2012 19:07:35
| I"ll have to confirm the type of fuel pump, but I can tell you we have fuel to the pump and have bled the system, but fuel is not being pushed to the injectors. |
| DGH
08-30-2012 10:32:49
72.25.192.4
Re: 1953 Oliver Cletrac - Fuel Pump in reply to Dave Goble, 08-30-2012 08:48:21
| When you bleed the system did you see or hear any air coming out?? If you did, then you lost fuel supply to the pump. Crank the engine and crack the lines one at a time at the injectors. Also look for a cracked fuel line, or a sport were it is rubbing on something where you may have a small hole were air could get sucked in!! |
| DGH
08-29-2012 17:31:13
72.25.192.4
| I would be surprized if the injection pump just failed like that. A more likely problem would be lose of fuel supply. Check for fuel from the filters. Could be anything like a plugged filter, water in the tank or crap in the tank blocking the fuel outlet. Has the tractor sat for a while without use? |
| Dave Goble
08-30-2012 08:54:19
75.101.82.12
Re: 1953 Oliver Cletrac - Fuel Pump in reply to DGH, 08-29-2012 17:31:13
| Good point regarding the filters, I should probably start with those first to see if there are basic issues there. There does seem to be sufficient fuel to the pump, it is just not being pushed to the injectors. The tractor does sit for a good part of the year, but we do fire it up and run it every few weeks; on the day this quit, we had been running it for several hours skidding logs off the hill and while it was sitting idling after we finished, it simply quit. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
