TractorLinks.com
Re: Internation 175b torque converter trans issue
Tfphill
08-28-2012 17:12:06
1- the engine sounds strong when in gear and reved. There is a slight dip in revs when put in gear
doesn't sound like its over labouring.
2- it works in 1st but feels as though it is not getting all that it should. 2,3,4 gives problem of drive shaft not turning at all.
3.- it has pushed well before. I am not sure y this happened. Tractor was pased down to me from my father.
4.- the steering is good and responsive.
I pulled the filter that sits above the torque converter. It look blocked. I am not sure if this is Whatyou have referred to as the strainer. It is a metal mesh type filter.
I also pulled the transmission filter. Looks like a paper type filter which is located to the left side of driver sitting position next to tranny. This filter feels kind of mooshy. I am not sure if it is because it bad or is this normal for a paper type that is exposed to oil.
I would also like to know if the fluid in the torque converter is fed from the hydraulic fluid tank?
Are there any other filters that I should look for besides these two?
