TractorLinks.com
Re: Internation 175b torque converter trans issue
Dennis K (WA)
08-28-2012 12:44:32
Tfphill,
Sorry if I have confused you. So far without any additional info I don't think the problem is the transmission. Ether the engine is weak or the converter is slipping due to a failure or lack of pressure or excessive load on the machine.
When in gear and tracks stalled if the drive line spins you ether have a slipping clutch pack or slipping steer clutches but based on your description that is not the case.
Does it sound like your engine is laboring, working, when in gear and reved up?
Does the driveline / engine act the same in all gears?
How did the problem develop or has it always been this way?
Does it steer normally? Are the brakes applied?
good luck
Dennis
Tfphill
08-28-2012 17:12:06
 Re: Internation 175b torque converter trans issue in reply to Dennis K (WA), 08-28-2012 12:44:32
1- the engine sounds strong when in gear and reved. There is a slight dip in revs when put in gear
doesn't sound like its over labouring.
2- it works in 1st but feels as though it is not getting all that it should. 2,3,4 gives problem of drive shaft not turning at all.
3.- it has pushed well before. I am not sure y this happened. Tractor was pased down to me from my father.
4.- the steering is good and responsive.
I pulled the filter that sits above the torque converter. It look blocked. I am not sure if this is Whatyou have referred to as the strainer. It is a metal mesh type filter.
I also pulled the transmission filter. Looks like a paper type filter which is located to the left side of driver sitting position next to tranny. This filter feels kind of mooshy. I am not sure if it is because it bad or is this normal for a paper type that is exposed to oil.
I would also like to know if the fluid in the torque converter is fed from the hydraulic fluid tank?
Are there any other filters that I should look for besides these two?
