HD5 LOADER DOZER
Anonymous-0
jUST IN QUESTION ABOUT STERING,TRACTOR WILL NOT TURN TO RIGHT GOING FORWARD. WILL TURN RIGHT GOING BACKWARDS. WHERE MIGHT THE PROBLEM BE?
hector,or anyone with noledge of problem.
The first think to do is adjusting your stering cluchs and the adjustement is on the bottom lever
stering cluch by the yoke and you need 3 inchs free travel at the top lever and adjusted your brake you need 1 3/4"to 2" free travel on brake pedal. let me know
The modle is hd5b 54.6hp. 2cycle diesel engine.Power from the engine is transmitted through a single plate over center type clutch and universal joint drive shaft assembley to transmission. Final drive gears and track drive sprockets are drivin by two multiple-disc stering clutches,one on each end of the stering cross shaft.
