Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem
[Return to Forum]
Chris up north
08-22-2012 15:51:06
24.138.160.110
Have a Case 480c. Clutch cutout is working perfectly when power shuttle is in reverse, but does not function at all when shuttle is in forward. Any ideas? New machine to me. Thanks in advance.
[Reply]   [No Email]
Chris up north
09-14-2012 05:04:27
24.138.160.110
 Re: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem in reply to Chris up north, 08-22-2012 15:51:06
Hi AJ
Well after fixing 3 different broken or chaffed spots in the solenoid wire, I finally got to the point where I believe one of the wires has a break inside the solenoid housing. Got a new solenoid, 2 minutes to install, clutch cut out works great. Upshift, downshift smooth as silk.
Thanks again for your help, very much appreciated!!!
[Reply]  [No Email]
AJ.
08-28-2012 10:55:57
92.4.154.201
If the machine has a good forward and reverse that suggests that the pressure is OK,the solenoid has to push the dump valve open to release the pressure,if that is not happening the most likely thing is 1 an electrical problem, 2 the solenoid is loose, 3 the solenoid has failed,check to see is tight, screw it on hand tight like a canister oil filter plus 3/4 turn, put two wires on to the pig tail,ground one and put power to the other to see if the clutch cuts out.
AJ
[Reply]  [No Email]
AJ.
08-25-2012 15:19:27
92.4.155.227
I have not had to replace a single one,it is more than likely a wiring issue,with the engine stopped unplug the pig tail from the solenoid and connect a test lamp to the wiring,get a second person to press the brake with the key switched on,the lamp should light each time the pedal or switch is pressed,if not check that none of the circuit breakers has popped out, if they are OK the wiring may be chaffed or have a bad connection,you can test the solenoid by grounding one of the wires and touch the other with a hot 12 volts,you should hear it jump,keep the engine stopped while working on the machine esp the transmission as it can take off and run over someone.
AJ
[Reply]  [No Email]
Chris up north
08-26-2012 05:10:17
24.138.160.110
 Re: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem in reply to AJ., 08-25-2012 15:19:27
Thanks AJ
I really appreciate your help. I also got my hands on a fluid pressure test procedure for the power shuttle. I will do that once I jimmy a pressure gauge with hose together. That should give me some good info as well. I will post the results.
Thanks again!!!
[Reply]  [No Email]
AJ.
08-25-2012 02:46:33
92.4.158.108
Is the machine going forward when the F/R lever is in neutral,if so it is an entirely different problem than you first explained but it usually carries more symptoms such as bogging the engine down when reverse is selected,pointless of me explaining if the machine is normal in neutral,if not come back.
AJ
[Reply]  [No Email]
Chris up North
08-25-2012 03:49:51
24.138.160.110
 Re: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem in reply to AJ., 08-25-2012 02:46:33
Hi A.J.
machine stays stationary in neutral and has lots of pull in reverse.
As I mentioned this machine is new to me. The cutout harness was not pluged in originally. I pluged it in, cutout worked in reverse.Posted original question. Did a bunch of work with it yesterday, now cutout is not functioning at all.????? I will mess with wiring again. Do solenoids breakdown often?
Thanks
[Reply]  [No Email]
mite-help
08-24-2012 20:45:42
166.249.200.181
fwd clutch pak plates maybe swarmed & it feels locked in; but probly in a fight with reverse pak.--reverse always wins---
[Reply]  [No Email]
Chris up north
08-25-2012 03:37:28
24.138.160.110
 Re: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem in reply to mite-help, 08-24-2012 20:45:42
Thanks mite-help
What do you mean by "swarmed".
[Reply]  [No Email]
AJ.
08-24-2012 13:01:05
92.4.149.27
That is the neutral start switch.
AJ
[Reply]  [No Email]
Chris up north
08-24-2012 05:33:46
24.138.160.110
Thanks A.J.
On the opposite side of the shuttle from the solenoid, there is a small cap with two brass electrical contacts on it. What is that? The shuttle wiring harness has a fitting that slides over those contacts.
[Reply]  [No Email]
AJ.
08-24-2012 03:03:51
92.4.130.21
if I understand correctly your clutch cut-out works in reverse but not in forward,secure the machine and go in under neat in front of the left back wheel with a flashlight,look up and you will see the shuttle unit,on the left back of the unit you will see what looks like a coke can on its side,that is the clutch cut-out solenoid,see that it is tight,check the wires coming off it so they are not getting caught in the F/R linkage,basically how thing works is pressure from the charge pump reaches the control valve,from there it is diverted to either the forward or reverse clutch pack,the pressure squeezes the clutch discs together and drive is engaged for the selected direction,when you press the clutch cut-out button the solenoid is energized and a plunger inside pushes a rod that opens a valve in the shuttle control allowing it to dump the fluid rather than send it to the clutch,the squeeze on the discs is released and the drive is suspended,check the solenoid is tight,if so there is an electrical problem some where else.
AJ
[Reply]  [No Email]
Chris up north
08-22-2012 19:22:33
24.138.160.110
Thanks Tractor vet.
Can you explain further. I am not a mechanic. Have a little mechanical know how.
[Reply]  [No Email]
The tractor vet
08-22-2012 17:53:59
76.212.225.255
Forward clutch pac is out
[Reply]  [No Email]
VicS
08-24-2012 16:27:02
70.195.1.179
 Re: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem in reply to The tractor vet, 08-22-2012 17:53:59
So it pulls in forward but just won"t stop when you push on the button? I wouldn"t worry about it, just use your foot throttle, it is the safest. Having the motor wide open and when your foot or finger slips off the switch is dangerous. I never use it.
[Reply]  [No Email]
Chris up north
08-25-2012 03:35:40
24.138.160.110
 Re: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem in reply to VicS, 08-24-2012 16:27:02
Hi VicS
The clutch cutout is activated when using the brake as well. It is nice to have when using the loader in a pile of dirt or gravel. Hit the brake, cutout kicks in, use the gas pedal to throttle up and the loader operates much faster.
[Reply]  [No Email]
VicS
08-25-2012 18:27:32
70.195.0.143
 Re: 1980 Case 480c Backhoe Shuttle Clutch Cutout Problem in reply to Chris up north, 08-25-2012 03:35:40
Maybe mine works differently, I have a 480E. It has the solenoid on the forward reverse shifter. I still never use it.There is a button on the floor and another one on the hyd lever. One thing about a 480 is with the same hyd pump and engine, the hyd is really fast. If they can dig it they are faster than almost anything. Same with the loader. moving cold patch away from a blender, my little 480 will lap a 580M. Shame they don"t make them anymore. Also you can haul them legal on a 15000 lb. trailer and a single wheel pickup. They just weight 10000 lb. and Newer 580 M"s weight 16000 plus.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
