Yesterday's Tractor Co.
Shop Now View Cart
Re: D6 pony motor
Old Magnet
08-16-2012 19:50:55
The washer butts up against the bearing to control the thrust on one direction. The crankshaft butts up against the other bearing to control the thrust in the other direction
If the crankshaft thrust face is in good condition the bearing can be moved and the dowel pin and lube holes can be redrilled using the housing as a guide. Drill 15/64 and ream to 0,249-0.250 for the dowel.
Thrust should be 0.010 to 0.016
Max allowable is 0.025.
Another option is to make an all new bearing out of T6 aluminum that fits the conditions.
Crankshafts can also be built up to restore original clearances and fit original bearing specs.
08-17-2012 04:54:27
 Re: D6 pony motor in reply to Old Magnet, 08-16-2012 19:50:55
Thank you oldmagnet, my thought was to drill the bearing, just thought I would ask a couple questions before doing that. Seems remotely crude, but if thats cat procedure then I will. Thanks again.
Old Magnet
08-17-2012 07:25:20
 Re: D6 pony motor in reply to chickensoup, 08-17-2012 04:54:27
The drill and ream procedure is the Cat method for original fitting parts. The moving and redrilling is a make do.
08-17-2012 17:04:16
 Re: D6 pony motor in reply to Old Magnet, 08-17-2012 07:25:20
I see, as long as it works I'll do what I have to. Seems I had to move the bearing in quite alot though, I did'nt actually measure it, but I bet it was close to a quarter inch. Why so far off with original cat parts? I have no known history of this engine so I suppose it could be a mix and match from years past.
Old Magnet
08-17-2012 20:28:04
 Re: D6 pony motor in reply to chickensoup, 08-17-2012 17:04:16
That is excessive, must be well worn or mismatched parts. What does the thrust face on the crank look like.
08-18-2012 02:59:42
 Re: D6 pony motor in reply to Old Magnet, 08-17-2012 20:28:04
Crank thrust face looks fine. If the pony motor is exclusive to the D6 series, I'm now wondering if this motor is from another series and that would explain why my new parts seem so far off. I should do just a little more research to make sure it will fit the machine properly. Souds like you have alot of expierience with these.
Old Magnet
08-18-2012 09:42:13
 Re: D6 pony motor in reply to chickensoup, 08-18-2012 02:59:42
Crankshaft part number did change from 4B2311 to 5F8405 but I don't know of any specific changes. Rest of the pony basic engine is the same, early or late. Just some of the bolt ons changed.
Yes, pretty familiar with the D6-9U's of which I have two. One is pony motor, the other direct electric start.
Not unusual to find crankshaft end play pretty far out of spec but 1/4" is pushing it.
