| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Re: D 5 C
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| NCWayne
08-13-2012 19:28:28
69.40.232.132
If your talking about it leaking fuel around the crank pulley then the seals in the fuel transfer pump are leaking into the crankcase. That said the oil, weakend with fuel will not provide proper lubrication to the engine so DO NOT run it until you get the problem repaired. Good luck. |
| kevinRM1976
08-14-2012 08:33:22
50.33.37.35
Re: D 5 C in reply to NCWayne, 08-13-2012 19:28:28
| NCWayne
08-14-2012 16:15:36
69.40.232.132
Re: D 5 C in reply to kevinRM1976, 08-14-2012 08:33:22
| What's your serial number? With that I can make sure what engine your machine has in it and tell you a little better what your going to be looking at. |
| kevinRM1976
08-14-2012 17:23:35
50.33.37.35
Re: D 5 C in reply to NCWayne, 08-14-2012 16:15:36
| 3mk00405 Thank you for any help you can give! |
| NCWayne
08-14-2012 20:43:49
69.40.232.132
Re: D 5 C in reply to kevinRM1976, 08-14-2012 17:23:35
| | Ok, looks like your machine has a 3204 engine. Like most CAT engines there are different configurations used dependent upon the machine it's in. Based on what I can find your transfer pump should be a plunger type pump located on the side of the injection pump, like the one, in drawing, in the link below. If that's what yours has then changing it is simply a matter of removing the lines and a few bolts to get the old pump off, and reversing the proceedure to get it back together. I found the pic by doing a Google search for 3204 CAT engine. Within the results are links to posts on other sites where guys are having the same problem. One even had the injection pump rebuilt trying to solve fuel leak into the crankcase, with no luck according to the post. That said, a leaking transfer pump is a very common cause of the problem your seeing, but if that doesn't fix the problem it appears it could also go as far as seals on the injection pump shaft leaking, although I've never seen that personally. Before buying a replacement pump give the guys at off Road Equipment a call. They can usually get either aftermarket, or NOS/OEM CAT parts much cheaper than getting them straight from CAT. Again good luck. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
