TractorLinks.com
Re: Cat DH8
NCWayne
08-03-2012 12:07:02
Even though it can be a PITA to check, and the turbo 'sounds; like it is working, that's where I'd start looking. I just replace a turbo on a customers machine a few months back that 'seemed to be working' and spun freely by hand and didn't appear to drag when spinning. Still my gut told me it was the problem and when the turbo shop tore it down they found the thrust bearings were shot and had been dragging causing the turbo to slow down instead of reaching full speed. Even a few thousand RPM'on the turbo can make a huge difference in the performance of the engine. Too, turbo seals leaking too much to the cold/suction side of the turbo can cause an excessive amount of oil to get drawn into the combustion chamber. A small leak will often go unnoticed as the oil will typically get burned off, but a larger leak will, in effect, flood the engine and will create black smoke due the amount of unburned fuel (oil and diesel) caused by the flooding. Either way the turbo would be my first choice to look at. Good luck.
Bob/Ont
08-03-2012 12:41:18
 Re: Cat DH8 in reply to NCWayne, 08-03-2012 12:07:02
Get a hose and a low pressure gauge into the intake manifold and check the boost under load.
Look for 10 to 15 PSI(not exact spec) but will give you an idea on turbo without tearing it down.
Later Bob
