| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Re: Cat 815 brakes
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| NCWayne
07-22-2012 20:04:52
69.40.232.132
What part of the brake chamber are you expecting to leak? I ask because I've built a couple of chambers on a CAT loader some years back and from what I remember about them the condition of the rod makes no difference because the only air pressure in the chamber is to the rear of the diaphram and not on the front side where the rod is. That being the case, the only reason air would leak around the rod would be because there is another problem internally causing the air to leak around the piston seal. With all of that said, again based on what I remember about the chambers I rebuilt (the ones with a ring of bolts around the end of the chamber), the stoke on the chamber CAT uses is longer than the stroke on a typical chamber like your talking about using. However if you can find a chamber that will match functionality, stroke, and mounting dimensions, there is no reason that something other than the actual CAT part won't work the same as the CAT part. |
[Reply] [No Email] | |
| Fritz Maurer
07-24-2012 20:48:53
216.137.136.147
Re: Cat 815 brakes in reply to NCWayne, 07-22-2012 20:04:52
| The stroke is one thing I never considered. You're right, I am stuck with those things. They are constructed so the air can be applied between the piston and the cylinder head, and the air is sealed in the chamber by O-ring seals around a chrome plated actuator rod (about an inch in diameter). The problem was with the rusty chrome ripping the O-rings and leaking air. The two that I did seem to be holding up OK, as long as I keep the dirt from building up and keeping them lubed so they don't rust. Thanks, Wayne, for your input. |
| NCWayne
07-26-2012 16:28:57
69.40.232.132
Re: Cat 815 brakes in reply to Fritz Maurer, 07-24-2012 20:48:53
| I just looked at the Bendix site and they carry parts for the actual rotochambers. That said, I also did a search for CAT brake chambers and now I remember what your talking about. I did build a couple of them about 10 years ago. The lower part of the canister is made like a Rotochamber and the actuator rod your talking about being pitted is hollow. When you apply air to the bottom of the chamber the hollow shaft rises and releases the parking brake. Then there is another regular pancake type chamber at the top that actually applies the brake to stop. The rod it moves runs through the middle of the hollow one. One good thing about that setup is that as long as the leaks don't get so bad that they drop pressure far enough to kick the parking brake valve back out, then you can live with them and still not be worried about the actual service brakes working. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
