JD 450C reverser problem
reidejo
New User
Tractor shifts fine into forward & reverser for about 30 to 45 minutes. After that it is very slow at changing gears (direction). Once it goes into gear it pulls and pushes good. I don"t know how long it would last because I shut it down when it starts this. Any ideas on where to start would be appreciated.
I forgot once it get warmed up you can hear a squealing noise in reverse
Thanks,
J. Reider
With the gear part of the transmission midway between 3rd and 4th , there is a neutral position..If any of the trans mods have been done , there should be a small cut-out made where this neutral is..Put it there , lock the brake, and run the HLR in all ranges.. Notice if there is a deeper than usual "pull-down" of rpms in any range..High , Low , Reverse.. If so, This would indicate warped clutches in the clutchpacks..This causes heat, that kills transmissions.. Another give-a-way is; do you need to use the clutch pedal between shifts of the HLR ??..Transmission is out of adjustment...Pressures are lower than needed...That causes killer heat that warps clutches in clutchpacks.. When a transmission heats up , oil gets thinner causing more leakage at questionable sealing sites..Have the transmission adjusted by someone that knows whats going on..Another good source of information is the "archives" in this site..
Steering clutches are run off the transmission pressure too..They will slip if transmission is low on pressure ..
(quoted from post at 19:05:56 07/17/12) With the gear part of the transmission midway between 3rd and 4th , there is a neutral position..If any of the trans mods have been done , there should be a small cut-out made where this neutral is..Put it there , lock the brake, and run the HLR in all ranges.. Notice if there is a deeper than usual "pull-down" of rpms in any range..High , Low , Reverse.. If so, This would indicate warped clutches in the clutchpacks..This causes heat, that kills transmissions.. Another give-a-way is; do you need to use the clutch pedal between shifts of the HLR ??..Transmission is out of adjustment...Pressures are lower than needed...That causes killer heat that warps clutches in clutchpacks.. When a transmission heats up , oil gets thinner causing more leakage at questionable sealing sites..Have the transmission adjusted by someone that knows whats going on..Another good source of information is the "archives" in this site..
Roy thanks for the reply. Sorry it has been so long, I have been busy baling hay. I ran the HLR in all ranges. There is some pull down in reverse, none that I could notice in High or low range. I do not need to use the clutch to shift between High and Low range. MY trans pressure is 160.
Thanks,
J. Reider
The shift between high and low isn't the issue..I'm referring to a direction change.. It should shift forward ranges to reverse without snapping your neck...And vise versa... I like to see 180 to 185 for pressures..
