| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Re: JD 450C reverser problem
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Roy Suomi
07-17-2012 19:05:56
76.190.200.252
With the gear part of the transmission midway between 3rd and 4th , there is a neutral position..If any of the trans mods have been done , there should be a small cut-out made where this neutral is..Put it there , lock the brake, and run the HLR in all ranges.. Notice if there is a deeper than usual "pull-down" of rpms in any range..High , Low , Reverse.. If so, This would indicate warped clutches in the clutchpacks..This causes heat, that kills transmissions.. Another give-a-way is; do you need to use the clutch pedal between shifts of the HLR ??..Transmission is out of adjustment...Pressures are lower than needed...That causes killer heat that warps clutches in clutchpacks.. When a transmission heats up , oil gets thinner causing more leakage at questionable sealing sites..Have the transmission adjusted by someone that knows whats going on..Another good source of information is the "archives" in this site.. Steering clutches are run off the transmission pressure too..They will slip if transmission is low on pressure .. |
[Reply] [No Email] | |
| reidejo
07-22-2012 19:27:08
72.26.25.223
| Quoting Removed, click Modern View to see
Roy thanks for the reply. Sorry it has been so long, I have been busy baling hay. I ran the HLR in all ranges. There is some pull down in reverse, none that I could notice in High or low range. I do not need to use the clutch to shift between High and Low range. MY trans pressure is 160.
Thanks,
J. Reider |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
