Installing bucket teeth?
Anonymous-0
I'm sure somebody on here will know. I'm making a heavy duty scarifier using H&L style bucket teeth and adapters with the rubber flex pins to hold the teeth on. The flex pins have raised points on one side and say back on one side. There is a slightly oval hole in the teeth. Which way should the raised points on the flex pins face? Back could mean either way depending how you interpret it. Thanks.
