Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: D8H
peter82
07-10-2012 08:13:17
I took the cover off and started dozer i could see the rack pin pulsating in and out and dozer would surge when it would go in and out how big of a job is this to fix how does this pump time? I have a parts engine that has a pump on it could i interchange the parts or would it be best to just order new thanks
Bob/Ont
07-10-2012 10:26:49
 Re: D8H in reply to peter82, 07-10-2012 08:13:17
Peter, if you want to get someone to do the work the pump is on an offset tang and doesn't require retiming when you remove and reinstall it. I would recommend going to the dealer and ask if one of their(OLDER)shop mechanics would do it for you. A fuel shop might want to do a complete rebuild. The drive spring will stop the surging. You could try using the whole pump from your parts engine. It's best to use new CAT parts, Talked to a guy with this problem on another engine that a fuel shop said they replaced the spring???? If you don't use the parts engine pump, practise on the parts pump first.Make sure you can always force the rack off when finished. Rack pulled back into pump from front. Come on back if this isn't clear.
Later Bob
peter82
07-10-2012 13:24:02
 Re: D8H in reply to Bob/Ont, 07-10-2012 10:26:49
any suggestions on removing dowell from cam
peter82
07-10-2012 11:31:52
you talk about rack going back into pump from front. the rack needs to go back into the pump towards govenor housing. i took the govenor housing off junk pump and i found the drive spring it looks good on the junk pump is there anything particular i need to check for on spring
peter82
07-10-2012 11:24:07
does pump have to come off or can i just take the govenor housing off and put it in from there as long as i dont adjust the fuel bolts i have a cat service manual
Bob/Ont
07-10-2012 20:30:57
 Re: D8H in reply to peter82, 07-10-2012 11:24:07
Peter I think you are doing okay with it.
Just make sure the gear is firmly attached to the cam.
I may have missed this pete but take a torch and heat the dowel in the cam red hot, let it cool and then it should pull out of the cam easily. If not reheat it and cool quickly with cold water, that will shrink it.
I think you should email me with your phone#
RBPlasma@gmail.com
Later Bob
