TractorLinks.com
IH TD6
Al Barclay
07-08-2012 10:56:39
Would any one here have an idea what new track pins and bushings would cost for an older TD6,i'm not even sure these parts are still available any more, probably would be a lost cause due to cost,just wondering,Al
Rays
07-09-2012 06:25:14
 Re: IH TD6 in reply to Al Barclay, 07-08-2012 10:56:39
This is for Tim in Alaska I have a good used head for a four cylinder TD6 INT crawler tractor. Let me know what your casting no. is I will match mine to make shure they are the same. I am located in Ohio My Phone no. is 330-223-1913
Ian Beale
07-09-2012 04:19:47
FWIW
I recall that a neighbour found that tracks for some of the small Fiat ag crawlers fitted TD 6's.
jm.
07-08-2012 18:38:18
Last pins and bushings I bought ( 6years ago) were about $ 800.00 for both sides. Most likely the dozer is not worth the expense.
tomtirediron
07-08-2012 11:29:13
Hi Al, Don't know about pins and bushings, but for what it's worth quoted 1400/side for a set of new TD-7 rails that would supposedly fit my TD-6. If I recall you have to then drill out your existing pads to fit the bigger bolt size of the TD-7. Nothing like putting $2800 into a $2500 dollar machine and getting a $2500 dollar machine. They're a nice little dozer love the gas start for winter, worked the snot out of mine for last 17 years wish there was an affordable answer. Good luck, Tom B.
tim in alaska
07-08-2012 17:07:49
 Re: IH TD6 in reply to tomtirediron, 07-08-2012 11:29:13
Anyone know what a good head would be. On for sale here with cracked head. Can these be welded. Thanks tim
tomtirediron
07-08-2012 18:01:11
 Re: IH TD6 in reply to tim in alaska, 07-08-2012 17:07:49
There is a place in Osseo Minnesota Called Northern Tractor and Equipment Company. They used to have quite a few parts for International Dozers. Look them up that would be the first place I would try.
tim in alaska
07-08-2012 21:17:48
 Re: IH TD6 in reply to tomtirediron, 07-08-2012 18:01:11
Hi tom. Thanks for the peply. Can u also advise if these heads can be welded and machined. Best regards. Tim
