| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Re: John Deere 450C tranny wanted
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Roy Suomi
07-07-2012 16:45:25
76.190.200.252
Just changing the transmission isn't that easy..The entire rear center section is the Transmission..The clutchpacks that do all the hydraulic gear changing are located in the front of the transmission case.. To remove the transmission case from the machine would leave the machine with only 2 engine side frame rails standing in the chassis and everything else gone ... If you can imagine that....And , whats to say that HLR was assembled right ..Everything has to jive or it won't work correctly.. Is the clutch pedal cross-shaft free to pivot on the left side of the engine clutch housing..There is a concoction of linkages on that left side that has to be free and moveable where that detented 1/2" vertical adjusting bolt is.. Inside the clutch housing behind the engine there are 3 adjustments.. One is the finger height of the engine clutch fingers..Another is the actual pressure setting at the pressure relief valve under the right hand opening [rubber plug], then the actual HLR speed of shift / pressure adjustment under the left handed rubber plug in the engine clutch housing.. All these have to jive....Then out of despiration there is a speed of shift adjustment on the right handed side of the transmission case inside a steel plug hidden by brake rods and fuel lines and battery cable.. Good fishing...Not a job for a novice..sorry |
| Roy Suomi
07-07-2012 16:52:47
76.190.200.252
Re: John Deere 450C tranny wanted in reply to Roy Suomi, 07-07-2012 16:45:25
| OH.. I almost forgot....There is a 3-3/4"pedal free-play adjustment that has to be done..That measurement is from the top of the pedal to where the throw-out bearing contacts the engine clutch fingers..This is adjusted on that left side 1/2" vertical bolt adjustment..Provided everything is free and moveable as stated before.. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
