Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: AC HD 10 steering brake problem
bill in colo
06-30-2012 20:14:28
Could you measure the rod on the other side ?
lemmond1
07-01-2012 15:42:10
 Re: AC HD 10 steering brake problem in reply to bill in colo, 06-30-2012 20:14:28
Thanks for your response. Yes, I have measured the other side and thought I was getting them the same length. I will try again. Roy
lemmond1
07-02-2012 19:10:55
 Re: AC HD 10 steering brake problem in reply to lemmond1, 07-01-2012 15:42:10
I remeasured the other side as you suggested and found it to be 3 inches longer. I will add three inches to the side that I broke. Hope this does it. Roy
lemmond1
07-03-2012 18:32:59
 Re: AC HD 10 steering brake problem in reply to lemmond1, 07-02-2012 19:10:55
I measured the other side and it was 20" pin to pin. I welded a threaded bolt on the side I broke to 20". The brake pedal sets up way too high and the brake still does'nt work. I took 1 and 1/2 inches off the rod and rewelded. It still doesn't work. I am going to try to adjust it from the rear inspection plate. Roy
Copyright © 1997-2015 Yesterday's Tractor Co.
