TractorLinks.com
Re: AC HD 10 steering brake problem
gemdozer
06-29-2012 11:45:17
You should have a small cover on the inspection cover under the fuel tank and you should see the exagon head rod adjustement if the HD10 is the same then the HD11
lemmond1
07-04-2012 13:58:01
 Re: AC HD 10 steering brake problem in reply to gemdozer, 06-29-2012 11:45:17
I think a new set of brak3 shoes would help. Does anyone know where I might get some new brake shoes? Roy
gemdozer
07-04-2012 16:17:00
 Re: AC HD 10 steering brake problem in reply to lemmond1, 07-04-2012 13:58:01
I should have a good used brake and band set for HD11 they should be the same than the HD10
lemmond1
07-05-2012 06:03:52
 Re: AC HD 10 steering brake problem in reply to gemdozer, 07-04-2012 16:17:00
What do you want for the brake shoes? Roy
lemmond1
06-30-2012 13:34:49
Thank Gem for your help. I have tried adjusting the brake behind the inspection plate you mentioned. The adjusting mechanism doesn't seem to do much toward alleviating this problem. I will keep trying. I have a manual but it doesn't specify the exact length of this rod. Roy
