Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: AC HD 10 steering brake problem
[Return to Forum]
lemmond1
06-28-2012 18:33:55
209.33.77.112
I broke the short brake rod on my dozer and welded it back together. Now my brake pedal is stationary on that side. How do I adjust it? Roy
[Reply]   [No Email]
gemdozer
07-03-2012 14:26:51
69.156.161.21
 Re: AC HD 10 steering brake problem in reply to lemmond1, 06-28-2012 18:33:55
I have a brake rod 21 inchs long 1/2" with fine tread at end and the other end she has a yoke for pine
[Reply]  [No Email]
gemdozer
07-02-2012 03:22:24
69.156.161.21
If your 2 rods are the same long are you adjusted the brake and they not working your brake are to worm or your rod adjustement tread and yoke femelle tread are scrap
[Reply]  [No Email]
lemmond1
07-03-2012 18:35:27
209.33.77.112
 Re: AC HD 10 steering brake problem in reply to gemdozer, 07-02-2012 03:22:24
The steering brake worked just fine before I broke it. The brake shoes look good. Roy
[Reply]  [No Email]
bill in colo
06-30-2012 20:14:28
75.104.96.54
Could you measure the rod on the other side ?
[Reply]  [No Email]
lemmond1
07-01-2012 15:42:10
209.33.77.112
 Re: AC HD 10 steering brake problem in reply to bill in colo, 06-30-2012 20:14:28
Thanks for your response. Yes, I have measured the other side and thought I was getting them the same length. I will try again. Roy
[Reply]  [No Email]
lemmond1
07-02-2012 19:10:55
209.33.77.112
 Re: AC HD 10 steering brake problem in reply to lemmond1, 07-01-2012 15:42:10
I remeasured the other side as you suggested and found it to be 3 inches longer. I will add three inches to the side that I broke. Hope this does it. Roy
[Reply]  [No Email]
lemmond1
07-03-2012 18:32:59
209.33.77.112
 Re: AC HD 10 steering brake problem in reply to lemmond1, 07-02-2012 19:10:55
I measured the other side and it was 20" pin to pin. I welded a threaded bolt on the side I broke to 20". The brake pedal sets up way too high and the brake still does'nt work. I took 1 and 1/2 inches off the rod and rewelded. It still doesn't work. I am going to try to adjust it from the rear inspection plate. Roy
[Reply]  [No Email]
jm.
06-29-2012 17:19:33
75.106.96.58
That rod adjustment wil be a funny looking has he calles it exagon looking but they are notorious for twisting off.. go very easy when you try suspect you have more problems because breaking the break rod is not normal I am thinking you will need to reline the brakes.. First dozer I ever owned in my life was a detroit powred cabel hd10 ac. Probably can find the service manual if you need one. jm. E-mail open
[Reply]  [No Email]
lemmond1
06-30-2012 13:27:48
209.33.77.112
 Re: AC HD 10 steering brake problem in reply to jm., 06-29-2012 17:19:33
Thanks for your response. I broke the short rod that is near the floor. A boisd'arc limb caught underneath and caused this. i have cut and welded the rod several times but I don't seem to get it right. The rod is about 18" long. Roy
[Reply]  [No Email]
gemdozer
06-29-2012 11:45:17
69.156.161.21
You should have a small cover on the inspection cover under the fuel tank and you should see the exagon head rod adjustement if the HD10 is the same then the HD11
[Reply]  [No Email]
lemmond1
07-04-2012 13:58:01
209.33.77.112
 Re: AC HD 10 steering brake problem in reply to gemdozer, 06-29-2012 11:45:17
I think a new set of brak3 shoes would help. Does anyone know where I might get some new brake shoes? Roy
[Reply]  [No Email]
gemdozer
07-04-2012 16:17:00
69.156.162.86
 Re: AC HD 10 steering brake problem in reply to lemmond1, 07-04-2012 13:58:01
I should have a good used brake and band set for HD11 they should be the same than the HD10
[Reply]  [No Email]
lemmond1
07-05-2012 06:03:52
209.33.77.112
 Re: AC HD 10 steering brake problem in reply to gemdozer, 07-04-2012 16:17:00
What do you want for the brake shoes? Roy
[Reply]  [No Email]
lemmond1
06-30-2012 13:34:49
209.33.77.112
Thank Gem for your help. I have tried adjusting the brake behind the inspection plate you mentioned. The adjusting mechanism doesn't seem to do much toward alleviating this problem. I will keep trying. I have a manual but it doesn't specify the exact length of this rod. Roy
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
